Perform this procedure on a Unix or Linux machine to verify that the software files downloaded properly. The MD5 checksum for each release is available from Extreme Networks Support portal.
  1. Calculate the MD5 checksum of the downloaded file:
    $ /usr/bin/md5sum <downloaded software file name>
    Typically, downloaded software files are in the form of .voss files.
  2. Verify the MD5 checksum of the software suite:
    $ more <md5–checksum output file>
  3. Compare the output that displays on the screen. Ensure that the MD5 checksum of the software suite matches the system output generated from calculating the MD5 checksum from the downloaded file.
$ /usr/bin/md5sum 5420.8.4.0.0.voss
d83cd61e0b115c83aca0c52c9dd5eb0e 5420.8.4.0.0.voss
View the MD5 checksum of the software suite:
$ more 5420.8.4.0.0.md5
9e8e4356ec44661514cd142e933dca59  5420.8.4.0.0_edoc.tar
4602bf5adbc0c31c0e5f5d38209d7b87  5420.8.4.0.0_mib_sup.txt
25be1902e954e3140d1072562c926d4b  5420.8.4.0.0_mib.txt
09d06a9dbbfdaa07cabd2000556d5d2b  5420.8.4.0.0_mib.zip
8e23c6632b5b7a9ec134418348baebea  5420.8.4.0.0_oss-notice.html
eb86e5991d8ce2a69b21510b993e0727  restconf_yang.tgz
561a5b566c42b68cc4b1fc3b1e71cf70  VOSSv840_HELP_EDM_gzip.zip
